I am having trouble getting RM properly setup. These are the steps I am taking, with the results being no File Plan option under Advanced Wizard:
2.1 community version, on Windows XP. Basic Alfresco functionality is working fine.
1. Download the module into C:\alfresco\amps.
2. Extract to c:\alfresco\amps
3. Run c:\alfresco\appy_amps.bat
4. Delete the c:\alfresco\tomcat\webapps\alfresco (folder)
After these steps, I don't have a workind RM module. I have read the AMP section on Wiki, but quite frankly, I don't get the use of the MMT. Is the apply_amps the only "build" utility I need to use? Thanks for your help!
