<?xml version="1.0" encoding="UTF-8"?> <process-definition xmlns="urn:jbpm.org:jpdl-3.1" name="bnotkwf:extended"> <swimlane name="initiator"></swimlane> <swimlane name="assignee"> <assignment class="org.alfresco.repo.workflow.jbpm.AlfrescoAssignment"> <pooledactors>#{bpm_groupAssignee}</pooledactors> </assignment> </swimlane> <swimlane name="repeat-assignee"> <assignment class="org.alfresco.repo.workflow.jbpm.AlfrescoAssignment"> <pooledactors>#{bpm_groupAssignee}</pooledactors> </assignment> </swimlane> <start-state name="start"> <task name="bnotkwf:submitAdhocTask" swimlane="initiator" /> <transition name="handle" to="handle-document"></transition> </start-state> <task-node name="handle-document"> <task name="bnotkwf:handleDocument" swimlane="assignee"> <event type="task-create"> <script> if (bpm_workflowDueDate != void) taskInstance.dueDate = bpm_workflowDueDate; if (bpm_workflowPriority != void) taskInstance.priority = bpm_workflowPriority; </script> </event> </task> <transition name="forward" to="repeat-handle-document"> </transition> <transition name="end-task" to="end"></transition> </task-node> <task-node name="repeat-handle-document"> <task name="bnotkwf:repeat-handleDocument" swimlane="repeat-assignee"> <event type="task-create"> <script> if (bpm_workflowDueDate != void) taskInstance.dueDate = bpm_workflowDueDate; if (bpm_workflowPriority != void) taskInstance.priority = bpm_workflowPriority; </script> </event> </task> <transition name="forward" to="handle-document"> </transition> <transition name="end-task" to="end"></transition> </task-node> <end-state name="end"></end-state> </process-definition>
