<repositories> <repository> <id>Alfresco Maven Repository</id> <url>https://maven.alfresco.com/nexus/content/groups/public/</url> </repository> </repositories> <dependencies> <dependency> <groupId>org.activiti</groupId> <artifactId>activiti-engine</artifactId> <version>5.12</version></dependency></dependencies>
package com.example.testingvaadin; import org.activiti.engine.*; import com.vaadin.server.VaadinRequest; import com.vaadin.ui.Button; import com.vaadin.ui.Button.ClickEvent; import com.vaadin.ui.Label; import com.vaadin.ui.UI; import com.vaadin.ui.VerticalLayout; /** * Main UI class */ @SuppressWarnings("serial") public class TestingvaadinUI extends UI { @Override protected void init(VaadinRequest request) { ProcessEngine processEngine = ProcessEngines.getDefaultProcessEngine(); final VerticalLayout layout = new VerticalLayout(); layout.setMargin(true); setContent(layout); Button button = new Button("Hello"); button.addClickListener(new Button.ClickListener() { public void buttonClick(ClickEvent event) { layout.addComponent(new Label("Thank you for clicking")); } }); layout.addComponent(button); } }
java.lang.NoClassDefFoundError: org/activiti/engine/ProcessEngines
I am trying to get Activiti and Vaadin working together so I can "play" with the two with some simple code and learn.
I have added the following dependencies to Maven:….I am getting the following error:java.lang.NoClassDefFoundError: org/activiti/engine/ProcessEnginesthe jars activiti-engine-5.12.jar and a couple of bpmn jars are in the Maven Dependencies path.This is probably a java beginner issue but what is wrong here?
Vaadin 7 changes the basic architecture of Vaadin applications significantly, more than it did in the previous major revisions.
Thanks udoderk:What I finally did was create a Vaadin project with the wizard and a Activiti project with a wizard. I thin wet up the dependencies for Activiti in the Vaadin project using Ivy.
