Hi.I've installed Alfresco (extracted from arc) and WCM module, both 2.1.0 ver.Then I've made all according to the instructions:- moved wcm-bootstrap-context.xml to appropriate folder- corrected custom-repository.properties, custom-hibernate-dialect.properties - updated MySQL connectorThen I've started to make all according to "Alfresco 2.1 Web Content Management Product Evaluation Guide"It was all Ok.. there were no errors.Only one litle problem: 15:27:54,767 WARN [org.alfresco.web.bean.wcm.CreateFormWizard] non fatal errors encountered parsing schema press-release.xsd
error parsing schema:
at line 51 column 114: src-resolve: Cannot resolve the name 'pr:company_footer_choices' to a(n) 'type definition' component.
But after searching the forum I've understood that there is no solution for it.But on step, whene i've rejected Alfresco.xml (from Mark account) and tried to edit it (from Admin account) i've got an eror:in browser:java.lang.IllegalArgumentException: Webapp name is mandatory.
in log:16:25:45,883 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
16:25:50,321 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
16:25:51,805 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
16:25:54,602 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: E:\CMS_Test\alfresco\alf_data
16:25:54,946 INFO [org.alfresco.repo.admin.patch.PatchExecuter] ßрþòõрúð ÷ðÿûðтþú, трõñующøх ÿрøüõýõýøÑ
