Hello,I installed alfresco 2.0 and everything works fine. Now I recently installed a second instance of alfresco in the same machine (to separate production from Preproduction) to test new features, changes, upgrades, etc.My system is:OS - Linux 2.6.18-1.2239.fc5smp - i386 GNU/LinuxDB - mysql Ver 14.12 Distrib 5.0.27, for redhat-linux-gnu (i686) using readline 5.0JDK - jdk1.5.0_11Alfresco - Alfresco Tomcat Bundle - alfresco-community-tomcat-2.0.0.tar.gzThese is my set-up for the second instance, called alfrescopre (for preproduction - very original uh? 😉 jeje).- SET CORRECTLY JAVA_HOME poiting to jdk1.5.0_11- DELETED FILES: /opt/alfrescopre/tomcat/shared/classes/alfresco/extension/custom-db-and-data-context.xml.origin
/opt/alfrescopre/tomcat/shared/classes/alfresco/extension/custom-hibernate-dialect.properties.origin
/opt/alfrescopre/tomcat/shared/classes/alfresco/extension/custom-db-connection.properties.origin
- FILES MODIFIED:* For tomcat>server.xml diff ./tomcat/conf/server.xml.origin ./tomcat/conf/server.xml
13c13
< <Server port="8005" shutdown="SHUTDOWN">
> <Server port="9005" shutdown="SHUTDOWN">
77c77
< <Connector port="8080" maxHttpHeaderSize="8192"
> <Connector port="9080" maxHttpHeaderSize="8192"
102,103c102,103
< <Connector port="8009"
< enableLookups="false" redirectPort="8443" protocol="AJP/1.3" />
> <!–<Connector port="8009"
> enableLookups="false" redirectPort="8443" protocol="AJP/1.3" />–>
*For alfresco.sh:diff ./alfresco.sh.origin ./alfrescopre.sh
4c4
< APPSERVER=/opt/alfresco/tomcat
> APPSERVER=/opt/alfrescopre/tomcat
Firstly I found some errors with my repositories configuration so I changed ../classes/alfresco/repository.properties diff /opt/alfrescopre/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/repository.properties /opt/alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/repository.properties
3c3
< dir.root=/opt/alfrescopre/alf_data
> dir.root=./alf_data
5,6c5,6
< dir.contentstore=/opt/alfrescopre/contentstore
< dir.contentstore.deleted=/opt/alfrescopre/alf_data/contentstore.deleted
> dir.contentstore=${dir.root}/contentstore
> dir.contentstore.deleted=${dir.root}/contentstore.deleted
8c8
< dir.auditcontentstore=/opt/alfrescopre/alf_data/audit.contentstore
> dir.auditcontentstore=${dir.root}/audit.contentstore
11c11
< dir.indexes=/opt/alfrescopre/alf_data/lucene-indexes
> dir.indexes=${dir.root}/lucene-indexes
14c14
< dir.indexes.lock=/opt/alfrescopre/alf_data/locks
> dir.indexes.lock=${dir.indexes}/locks
17c17
< index.recovery.mode=FULL
> index.recovery.mode=VALIDATE
72c72
< db.name=alfrescopre
> db.name=alfresco
74,75c74,75
< db.username=alfrescopre
< db.password=alfrescopre
> db.password=alfrescoThat solved some of the errors and now I have available the second Tomcat on port 9080 but alfrescopre is not workingThis is my currently alfresco.log for preproduction:11:15:00,644 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'serverConnector' defined in class path resource [alfresco/core-services-context.xml]: Initialization of bean failed; nested exception is java.io.IOException: Cannot bind to URL [rmi://localhost:50500/alfresco/jmxrmi]: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
at javax.management.remote.rmi.RMIConnectorServer.newIOException(RMIConnectorServer.java:814)
at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:431)
at org.springframework.jmx.support.ConnectorServerFactoryBean.afterPropertiesSet(ConnectorServerFactoryBean.java:183)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1059)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:363)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:269)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:320)
at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3763)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4211)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
Caused by: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:118)
at com.sun.jndi.toolkit.url.GenericURLContext.bind(GenericURLContext.java:208)
at javax.naming.InitialContext.bind(InitialContext.java:359)
at javax.management.remote.rmi.RMIConnectorServer.bind(RMIConnectorServer.java:635)
at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:427)
… 35 more
Caused by: java.rmi.AlreadyBoundException: alfresco/jmxrmi
at sun.rmi.registry.RegistryImpl.bind(RegistryImpl.java:123)
at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:375)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:240)
at sun.rmi.transport.Transport$1.run(Transport.java:153)
at sun.rmi.transport.Transport.serviceCall(Transport.java:149)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:466)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:707)
at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java:247)
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:223)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:343)
at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:116)
… 39 more
11:15:00,652 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Excepción enviando evento inicializado de contexto a instancia de escuchador de clase org.springframework.web.context.ContextLoaderListener
… 35 more
… 39 more
11:15:00,657 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Excepción enviando evento inicializado de contexto a instancia de escuchador de clase org.alfresco.web.app.ContextListener
… 35 more
… 39 more
Does someone have idea about what can I check/change to solve this?.Thank you very much in advance for any help.Best Regards.-Julio-
