<bean id="authenticationComponentImpl" class="org.alfresco.repo.security.authentication.jaas.JAASAuthenticationComponent"> <property name="realm"> <value>DEFAULT.REALM</value> </property> <property name="jaasConfigEntryName"> <value>Sample</value> </property> </bean>
HiWhich repo version are you using?For 2.0 and after the bean to override is authenticationComponent and not authenticationComponentImpl.…Andy
did you solve your problem?I'm getting the same error:2007-07-02 11:12:37,430 ERROR [org.springframework.web.context.ContextLoader] Context initialization failedorg.springframework.beans.factory.BeanIsNotAFactoryException: Bean named 'authenticationDao' must be of type [org.springframework.beans.factory.FactoryBean], but was actually of type [org.alfresco.repo.security.authentication.RepositoryAuthenticationDao] I installed v. 2.0 under JBoss, and this is my jaas-authentication-context.xml :<?xml version='1.0' encoding='UTF-8'?><!DOCTYPE beans PUBLIC '-//SPRING//DTD BEAN//EN' 'http://www.springframework.org/dtd/spring-beans.dtd'><beans> <!– The authentication component. –> <!– Jass authentication - most of the config goes somewhere else –> <bean id="authenticationComponent" class="org.alfresco.repo.security.authentication.jaas.JAASAuthenticationComponent"> <property name="realm"> <value>INSIEL.IT</value> </property> <property name="jaasConfigEntryName"> <value>Alfresco</value> </property> </bean> <bean id="alfDaoImpl" class="org.springframework.transaction.interceptor.TransactionProxyFactoryBean"> <property name="proxyInterfaces"> <value> org.alfresco.repo.security.authentication.MutableAuthenticationDao </value> </property> <property name="transactionManager"> <ref bean="transactionManager" /> </property> <property name="target"> <bean class="org.alfresco.repo.security.authentication.ntlm.NullMutableAuthenticationDao" /> </property> <property name="transactionAttributes"> <props> <prop key="*">${server.transaction.mode.default}</prop> </props> </property> </bean></beans>
<bean name="authenticationDao" class="org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao" > <property name="allowDeleteUser"> <value>true</value> </property> </bean>
HiThe config example is wrong.See http://issues.alfresco.com/browse/AR-1564 <bean name="authenticationDao" class="org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao" > <property name="allowDeleteUser"> <value>true</value> </property> </bean> Should sort this out.Andy
15:00:11,732 ERROR [alfresco.smb.protocol] Closing session due to exception org.alfresco.error.AlfrescoRuntimeException: Not implemented at org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao.getMD4HashedPassword(DefaultMutableAuthenticationDao.java:394) at org.alfresco.repo.security.authentication.AuthenticationComponentImpl.getMD4HashedPassword(AuthenticationComponentImpl.java:107) at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.doNTLMv1Logon(EnterpriseCifsAuthenticator.java:1267) at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.doNtlmsspSessionSetup(EnterpriseCifsAuthenticator.java:942) at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.processSessionSetup(EnterpriseCifsAuthenticator.java:637) at org.alfresco.filesys.smb.server.NTProtocolHandler.procSessionSetup(NTProtocolHandler.java:407) at org.alfresco.filesys.smb.server.NTProtocolHandler.runProtocol(NTProtocolHandler.java:221) at org.alfresco.filesys.smb.server.SMBSrvSession.runHandler(SMBSrvSession.java:1450) at org.alfresco.filesys.smb.server.SMBSrvSession.run(SMBSrvSession.java:1351) at java.lang.Thread.run(Thread.java:595)
