<?xml version="1.0" encoding="UTF-8" ?> <!– Document : description.xsl Created on : 28 March 2007 Author : Scott Middleton Description: This stylesheet transforms the description section of a Process Unit. –> <xsl:stylesheet version="2.0" xmlns:xhtml="http://www.w3.org/1999/xhtml" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:pr="http://www.alfresco.org/alfresco/pr" xmlns:fn="http://www.w3.org/2005/02/xpath-functions" xmlns:mt="http://www.objectconsulting.com.au/mentor/mt" xmlns:pm="http://www.processmentor.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:alf="http://www.alfresco.org" > <xsl:output method="html"></xsl:output> <xsl:template match="/"> <xsl:apply-templates select="pm:processunit"/> </xsl:template> <xsl:template match="pm:processunit"> <h1>Deliverables</h1> <xsl:choose> <xsl:when test="pm:deliverables/pm:overview"> <p><b>Overview</b></p> <xsl:value-of select="pm:deliverables/pm:overview" disable-output-escaping="yes" /> </xsl:when> <xsl:otherwise> <p> The following are deliverables for the <xsl:value-of select="pm:name" /> Process Unit: </p> </xsl:otherwise> </xsl:choose> <xsl:apply-templates select="pm:deliverables/pm:deliverablereference" /> </xsl:template> <xsl:template match="pm:deliverablereference"> <p>Ref: <xsl:value-of select="pm:ref" /></p> <!– pm:ref is something like "/content/xml/Somefile.xml" Note: this file does exist! –> <!– if i comment this 'if' and its contents out then there is output –> <xsl:if test="pm:ref"> <xsl:variable name="deliverableRef" select="pm:ref" /> <xsl:variable name="deliverable" select="alf:parseXMLDocument( $deliverableRef )" /> <p> <xsl:if test="$deliverable"> <xsl:value-of select="$deliverable/pm:name" /> </xsl:if> </p> </xsl:if> </xsl:template> </xsl:stylesheet>
file:///C:/Alfresco/dummy.xsl; Line #0; Column #0; javax.xml.transform.Transform erException: unable to create uri http://preview.admin.processmentor.www--sandbo x.10-8-8-117.ip.alfrescodemo.net:8180/content/xml/deliverables/Application Model .xml file:///C:/Alfresco/dummy.xsl; Line #0; Column #0; java.lang.NullPointerException
<xsl:variable name="deliverableRef" select="replace(pm:ref,' ','%20')" />
